merc 350 excessive smoke
Lorne Walter
I have a 1961 merc 350 40hp, in the manual i found online it says to mix the oil at 20:1 so I did. the motor putout so much smoke when trolling, it made us all sick after a few hours. Once in a while, the blue smoke will become so thick, we need to drive away a bit, and you can see clouds of blue billowing of the lake surface, then it clears out after a minute at full speed. so we can troll again. and any suggestions? this is my first boat so I am not well experienced.
The manual stated you use the 50:1 ratio if you have the thru hub exhaust and 20:1 if non thru hub. Don't know why but doubt its about oil being crap as its same oil
I was referring to that old, 30 wt crap (which was all we had back then) that carboned up and fouled plugs like crazy.
Jeff
