ShoMeStyle
Bought this Evinrude 115 crossflow(Not sure on year) from a marine shop about 2 years ago, everything has been great until this weekend. Was on plane cruising like normal and it lost power than died and over heat alarm went off. After I let it cool down, it struggled to start back up. When it did, I pulled wires on each cylinder, one at a time and found the cylinder that caused no change.
Got back home and pulled the spark plug. It is crusty and black.
Decided to take the cylinder head off to check the cylinder and it looks like the exhaust side of the piston melted off? Also on the top of the piston. I can touch the top ring and wiggle it but it doesn't appear broken.
Cylinder seems scored up and I believe has some melted metal stuck to it?
I obviously need to fix what caused this, but I'm not too sure what else to check...the carbs all seem good, nice and clean. The thermostats and water passages seem okay, stats opened up in boiling water.
I am new to working on 2 strokes and outboards. Although I'm mechanically inclined, I'm wondering if this thing is even worth salvaging and what my options are?
Do these motors have cylinder sleeves you can replace? or do I need to get it bored out? Will a hone suffice?
How hard is it to replace the piston?
I don't have the money for a new motor.
