The Offensive Janitor
I'm not a mechanic so bear with me here... my motor is an '87 Mariner 90 3 cyl 2 stroke. I was leaking oil from the prop bearings, so I changed the prop seals... I've ran into a few issues along the way but I am confident that everything is reassembled correctly... but upon reassmbling thebearing carrier, I am unable to completely tighten the 2 bolts down, and am left with a gap maybe 1/4" between the housing and the bearing carrier.... I do have proper F-N-R with loose bolts, but if I tighten even a ****hair more on either bolt, it won't go into reverse... should I now add the gear oil and try rocking F-N-R to see if that makes the gears mesh better, or is this that "backlash" that was mentioned a bunch of times in my Clymer's manual (which is about as useful as tits on a bull) ... Any help appreciated!!
