I have a mid 90s Mariner 9.9 on my jon boat. It's the first boat/motor I have ever owned, so I'm learning as I go.
The motor was idling fine and running fine at low speeds under load. However, at WOT it would bog down and quit.. usually about 30 secs in. If I pull the choke out then push it back in, it would recover for a short period.
I pulled the carb, sprayed everything down with carb cleaner and blew it out. It all appeared to be in good condition with no buildup and no debris. After putting it back together, the motor will not stay running. I give it one pull with the choke out with throttle at idle, then one pull with choke in and throttle at start position. It turns over, surges, smokes, then dies.
I also pulled the plugs, they were black, gummy and wet. They have been cleaned with a wire brush and replaced. If I pull them after trying to crank, they are wet.
I know I'm missing the most simple thing here.. so any pointers? Does anyone have a link to a "Mariner carb for dummies" internet article? Can someone slap me in the back of the head and tell me the obvious thing I'm missing?
Thanks for any help!
