Can anyone assist me ? Just got the engine ready for summer. It went into the garage for winter about 5 months ago. I changed the plugs, changed the oil filter/fuel filter and fresh engine oil. Started her up and got the dreaded check engine light. The code is showing MAP sensor 2 and the book says "this condition will be caused by disconnected, kinked or clogged MAP sensor hose or clogged inlet manifold gas filter". I have looked at the MAP sensor...the hose doesn't look kinked, but am I right that I would have to take thje manifold off to get at the inlet manifold gas filter ? Happy to do that if I have to, but it looks complicated. I put the boat in the water, and the engine runs very rough and will not go above 3,000 rpm which I guess is because the fuel/air mixture is messed up. Engine is a Johnson/Evinrude 50hp 2003 model J50PL4ST any help would be muich appreciated !
