Sorry if this has been asked in a previous thread, or is a relatively simple fix, I’m a complete mechanical novice. I’ve recently bought a bf10 (?) 10hp fourstoke and have the following symptoms:
Starting issues: takes an extremely long time and a lot of effort to start, pulling the choke out seems to make it worse as it dies immediately unless the choke is instantly pushed back in, then has to be revved very high to keep from dying straight away
Accelerating: unless high revs are put on just before putting in gear, it will die as soon as load is put on, if it has idled (tickover)for any length of time it will die as soon as it’s put in gear
Low speed: will die in any low rev manoeuvre such as pulling along side a bank, where switching between forward and reverse is necessary. engine runs well as soon as you are cruising at consistent revs but at low speed (3knots estimate) the revs will lower themselves to tickover without any throttle input and then it will die
Water exhaust: dribble to slow drip of water out of the exhaust only, not sure if related to above issues or just a separate issue
Engine works great as soon as it gets going but obviously these issues make any usage quite stressful
Like I said I’m completely new to outboard maintenance and trouble shooting so would appreciate any pointers
D
D
