Loud knocking noise
Let’s start from the beginning:
I was losing lower unit oil from my monitoring tank and after troubleshooting to my lower unit I removed and replaced the 2 o-rings on the engine coupler yoke.
After re-assembling the outdrive to the boat I ran the engine in the driveway and no leak was found.
The first time back on the lake the engine started making a loud knocking noise at high RPM and before outdrive is trimmed up. The noise goes away after boat is on plane but returns when I increase the throttle.
I re-pulled the outdrive after some suggestions it was the yoke u-joints were worn but the noise is still there after replacing the universal drive shaft, seals and bearings except the drive gear assy since it looked good. The noise wasn’t there before pulling the outdrive so I’m hoping it’s something someone has encountered before.
