Leaky water tube?
Angry
Hey guys, chasing an overheat in my 1987 evinrude 40 VRO.
tried to flush the water passages with a garden hose. Noticed this pin hole leak in the tube. It looks pretty round, not sure if it’s a corrosion hole, or a factory weep hole. What do you think?
if it’s a leak, could I patch it with some JB weld or other epoxy?
Conflicting advice. One says the hole should be there . One, on another forum, says repair the hole.
Changed water pump, thermostat, bypass valve, temp sensor. Currently have head off. Changing head gasket, which I think was the likely culprit. A298F86A-882F-4831-9F00-C50D1BECDA84.jpg
the head gasket has several of these holes. This one being the worst. I think water was getting into bottom cylinder, as it had much more carbon than the top.
