Thanks for that. I was thinking that or possibly a damaged water pump, the noise does sound more like metal on metal though.Sounds like it might be a broken tooth on a gear ( forward ) most likely.
No metal chips, water, smoke etc.Any metal chips, water, or burnt gearoil seen during inspection? How did you determine the noise is coming from the gearcase?
4 strokeA 2 stroke or 4 stroke ?
Haven’t drained the oil.Did you drain the gear oil? Not the engine oil, but the gear case by the prop. Was there metal in there or did the oil that came out appear metallic in a bright light?
will try this as either way lower unit has to come off I thinkRemove lower unit.----Start motor momentarily.----Listen for noise.
True. Thanks.You have to start somewhere to find a path forward.
