Knocking lower unit.
Norris
I have a knocking noise lower unit. Yamaha 60 2004.
The noise is audible when engine running in neutral and also when in both forward and reverse.
Any metal chips, water, or burnt gearoil seen during inspection? How did you determine the noise is coming from the gearcase?
No metal chips, water, smoke etc.
lifted the engine out of the water and the sound clearly coming from the bottom leg. Engine runs well and again no smoke on start up.
Did you drain the gear oil? Not the engine oil, but the gear case by the prop. Was there metal in there or did the oil that came out appear metallic in a bright light?
