M
MIKE MARTIN
Guest
I HAVE A 1999 175HP JOHNSON OU
I HAVE A 1999 175HP JOHNSON OUTBOARD IM HAVEING TROUBLE WHEN I IDLE IT WANTS TO DIE OUT IF I GIVE IT GAS IN NEUTRAL IT SMOKES ALOT WHEN I GET READY TO TAKE OFF IT BOGGS OUT IF I TAKE THROTTLE AND GO DOWN VERY SLOW SOMETIMES IT WILL GO ONCE IM GOING IT RUNS FINE I SEE A SOME OIL COMING OUT OF CARBS I TOOK IT IN THAY SAID IT WAS THE VRO PUMP I WANT TO BUY A NEW ONE DO YOU THINK THIS IS THE PROBLEM THEY ALSO SAID I NEED TO REBUILD CARB BECAUSE OF EXESS OIL IN CARBS DO YOU THINK THIS IS NESSASERY IT IS VERY EXPENSIVETO REBUILD CARBS
