16ftstriper
Yesterday while out with my 1999 Johnson 50hp 2 stroke I accidentally got in some shallow water and had to run through some sand. After making it through a good amount of sand I headed back to the launch, and about 5 minutes later cruising back the overheating buzzer came on. I slowed the boat down to idle and let it cool and shut it off for a while. I limped it back to the launch and the water coming out the tell tale was warmer than normal.
Today I put in a new water pump, new thermostat, and flushed the entire engine. There was a lot of sand everywhere in the cooling passages but got it all out. I even pulled the water passage cover to flush it out. I took it out to test, and it never overheated, but it seemed like the water coming from the tell tale was warmer than normal. It is normally cold/slightly warm, while today it was pretty warm (not hot). It is shooting water out the tell tale better than it was before, but I am not sure why the water is warmer than before.
I think it could be blown head gaskets or an improperly installed thermostat, but I'm not sure. I did a compression test and it was exactly the same as it was a week ago, and the spark plugs look normal. Any advice would be appreciated!
