Long time reader with a motor that is haunting me!
I'm helping a friend get his Whaler going for the first time after sitting a good 5 or so years and it has a 1995 Johnson 90 HP Ocean Runner on the back that's in good shape. Model J90SLEOC. The problem I have after going through it and starting for the first time is that it will start and run but if left alone will stall/die off after no more than 10-15 seconds.
The compression checked out great and so did the spark. This engine has the plastic carbs and all the funky timing linkages with the "Covered" flywheel. I rebuilt all the carbs and the carb bodies of which came out really nice. All carb bowls have been sealed where those "BB's" are as those leaked like crazy and 2 had fallen out. Fuel system is now "Tight" and has no leaks with all new gaskets throughout. Replaced the water pump, gear oil and thermostats as well as a thorough go over with a fine tooth comb.
What I have found is if I can start it and quickly run back to the engine and move the timing lever which protrudes out of the top most shroud over to about midway it will idle all day long! As soon as you let go, the engine will die by itself in about 10-15 seconds. I followed the book to check the timing but of course I do not have the special tools to analyze the system. This is where I have left it and frustrated in about December. Now it's getting to be boating time and I want this done so I do not have it in my head!
Any and all advice is greatly appreciated, thanks in advance!
