Johnson 70 hp and evinrude 55 hp midsection
That's what I needed to know. I have a outboard jet lower unit and wanted the short shaft mid section now I can order the drive shaft. Thanks for the info. One more thing the 55 mid section has 2 water tubes for the water pump but I have the water pump off the 55 can I use it or can I plug 1 of them off.
Thank you again. I'm new to johnson/evinrude are you talking about the thick plate between the power head and the mid section? If so will I have to find a short shaft late model adapter plate? Both my motors are complete the 55 hp is short shaft and the 70 is long shaft. Can I change the exhaust on the 70 hp long shaft adapter plate to the short shaft?
