Rehabbing a long-stored 2000 Johnson50HP. Installed new starter motor, cranks engine as it should but continues running when key is turned from “start” to “run”position. Starter motor turns off when ignition is turned off, does not run when key is turned back on to “run” position. Turn to “start”, engine cranks but again starter motor keeps running when key is turned back to “run”. I replaced solenoid this morning, same thing. Is this likely an ignition switch problem at the console?
