ptownbubba
I have a 50 HP Johnson not sure of year,as the decal is smeared showing those specs. This the cover, year ????
It will start and run, but then die, seems to keep running if you pump bulb,,,, the fuel filter never gets more than 1/3 full,, [after pumping bulb ] then you can watch it drain, then motor quits.
This just happened suddenly on the river, I was thinking the VRO needed rebuilt, the VRO has already had the oil pump disabled, so it is just a fuel only pump now, I assume it operates on an engine vacuum system, so I guess a look at all those hoses is the first thing to do,,,,perhaps save $150,,,,,,,,as far as the seal kit,,,,,,,,,,, how many different flavors of kits are there,,,, or do all VRO-s take the same kit ?
Mounted on back side of air intake,
