gunsgunsguns
I have a 1993 Ocean Runner 225 that starts easily then dies when key is released from "start" position to "run" position. Same occurs when kill switch and shift interrupt switch are disconnected. And same when port temp sensor is disconnected. I also replaced the ignition switch. I still get the same problem. I double checked the function of the new ignition switch and all is according to specs. I recently replaced the flywheel, stator, timer base and power pack because they were all bad. I'm completely baffled at this point. Any ideas?
Thanks,
Mike
Thanks,
Mike
