Joe Reeves static timing video
bigjohnson
Anybody have info where I can find a jr static timing video for
97 150 hp carb 2 stroke. I have the written instructions but
Would like a visual if available.
My information says that the timing is set at the factory and needs no adjustment.-----What is your motor doing / not doing ?
Remove stabilizer and chunk it in trash. Set max timing at 21° t cranking speed. Make sure you use dial indicator to set the timing pointer
Some people post to set at 23.
Did I do this correct? Per instructions:
Max timing adjust: I moved throttle lever to place max spark advance SCREW against stop and moved screw to get 22.5 degree btdc.
Then primary pickup Tim adjust I held throttle arm so that idle stop SCREW is against stop and got 5 degree atdc.
Next I'm unsure about.
How do i check WOT to be 19 degrees btdc?
