Pel's Garage
Hello,
A friend of mine asked for my help with his boat engine. I usually work on modern cars, so I decided to do some research.
Here's what he has:
From my research so far, this is a carbonated engine. OMC is no longer around, was bought by Johnson.
Symptoms: engine starts but dies fairly quickly.
He said he was going to buy a fuel pump, so I advised him to find out what is the return policy as it may or may not be the fuel pump.
I figured it's going to be some sort of a fuel delivery issue, so either a pump, a fuel pressure regulator or the carb.
1. Any diagrams of the fuel system available anywhere?
2. Is the fuel pump fairly accessible?
3. Any tips on the carburetor? (haven't worked on carbureted engines)
4. What is a normal fuel pressure between the pump and the carb? (Psi)
I was going to check the basics first but given the engine does start, the battery has enough charge, a kill switch isn't malfunctioning.
Appreciate any tips and/or documentation.
Thank you.
Here's what he has:
Thank you.
