I am rewiring a boat/1996 Crusader 350XL. I have what I believe is called an ignition relay mounted to the same bracket as the starter relay. It is a small plastic boxed relay. Question is, what does this little relay operate or energize? I guess the answer to that will also tell if it might only require momentary "start" power or constant power when running. I can get the starter to operate without powering the little plastic relay. When I energize the plastic relay it does click but I can not determine what it is operating or suppose to operate. My only guess is it may operate the choke. Very uneducated in this area guess at that. It does appear to be wired to something though. But tracing out the wire through the taped up wiring harness and where it is located looks daunting if not impossible. Any help, greatly appreciated.
