hello all I’m working on the electrics of my 30 year old Tiara.
i have a series of warning lights on the dash that are not hooked up. Behind the dash are these two red circuit boards that seem to control the warning lights. I’ve traced some of the wires from the circuit board and am trying to figure out two things
1 does my warning light module work
2 how do I wire it.
I ll post a pic in a minute but here is background info
boat is a 1987 Tiara that originally came with twin Chevy small block 350 engines with alpha 1 drives rated at 260 HP.
the boat was repowered in 2001 with twin Chevy small Block 350s rated at 250 HP with 2bbl carbs and alpha one gen 2 drives
i believe that when the motors were swapped is when the lights were disconnected.
I dont know if they they were disconnected for a reason or if the mechanic just didn’t bother.
I’m hoping to be able to get my warning lights working properly again
can someone tell me how to test the control module to see if it works? For each warning light there are two wires on the control module.
One wire going to the (what I believe is) signal wire on the back of the respective gauge. And one wire to the warning light.
the module has 4 of these wire pairs two wires each for:
water temp
oil pressure
battery
fuel tank
there is also one additional wire on the control module.
the lone wire has been cut so I cannot confirm where it was connected. It’s a grey wire spliced into a black wire. The splicing matches the rest of the factory wiring so I’m assuming the black wire it’s soliced into is from the original tiara harness.
My my best guess is that the black oem harness wires are battery negative.
on the warning lights there are two wires, one from each warning light that goes to corresponding pair on the control module and one that is daisy chained together for all the warning lights to a purple wire. I’m assuming the purple wire is main harness OEM SWITCHED battery positive.
id like to test the module off the boat .
can anyone confirm I’d the cut wire from the module with the black wire should be to battery negative?
Can anyone tell me how to replicate / trigger the signal wire connected to the gauge? Should a full ground from the signal wire activate the warning light?
2 how do I wire it.
water temp
oil pressure
battery
fuel tank
