A few weeks ago it started stalling in gear at idle intermittently. Then today it ran all day, at the end of the day I idled in gear and it stalled. Wouldn't restart. Leaking fuel. Then saw fuel leak out of the upper right corner of the starboard side of carb when I pumped primer bulb. Let sit for couple hours, then it started, barley. But wouldn't idle and didn't seem to be running well, continued leaking fuel.And what is your motor doing / not doing that leads you to believe it is a carburetor problem ?-----Any other trouble shooting done ?
Ok, thanks. I just figured if I open up the carb might as well clean and rebuild with kit with float that is available. Carb hasn't been rebuilt in 4+ years.I would say that you need to look at the float / float valve.---------Simple repair and I would not call it a " rebuild " if that leak is the problem.
Thanks! There is a small black rounded, hollow ( in the shape of a square) cylindrical thing attached to the carb body, it looks to be plastic. Is that ok to soak overnight as well?I did not know that then pull the jet and soak it with the carb. I use a gas welding tip cleaner it has ribs but does not work as a file. Allways replace the fuel lines as well and at least clean the fuel pump. If the diaphram in the pump is stiff replace it.
