jasoncalleja
Honda states that they use the same engine for the Honda BF90D year 2010 15vtec as the Honda Fitt/Jazz. i would like to ask these engines that i found and are used on the same cars with the same Displacement: 1,496 cc (91.3 cu in) and Bore x Stroke: 73.0 mm × 89.4 mm (2.87 in × 3.52 in) but with different power. could some one tell me what is the difference in these engines to have different Hp.
[h=3]L15A2 i-DSI[edit][/h]It debuted in Honda City/Fit Aria four door Sport-sedan in November 2002.[SUP][2][/SUP]
It debuted in JDM Fit and Mobilio Spike in September 2002.[SUP][3][/SUP][SUP][4][/SUP]
- Offered in the Fit Aria and Partner in Japan.
- Displacement: 1,496 cc (91.3 cu in)
- Bore x Stroke: 73.0 mm × 89.4 mm (2.87 in × 3.52 in)
- Compression Ratio: 10.8:1
- Power: 66 kW (90 PS; 89 hp) @ 5,500 rpm
- Torque: 131 N·m (97 lb·ft) @ 2,700 rpm
- Top Speed: 180 km/h Speed Limiter, 240 km/h Sport mode
- unleaded gasoline only
- Source http://www.honda.co.jp/auto-archive/fit-aria/2005/grade-data/
- Available in the Fit, Fit Aria, Airwave, Mobilio, and Mobilio Spike in Japan. Sold throughout the world with 5-speed manual or CVT options in the Fit/Jazz and City. Canadian and US Fit models will have a 5-speed automatic instead of the CVT.
- Compression Ratio: 10.4:1
- Power: 81 kW (110 PS; 109 hp) @ 5,800 rpm
- Torque: 143 N·m (105 lb·ft) @ 4,800 rpm
- Top Speed: 180 km/h (Electronic limited)
- Rod Length :149 mm
- Rod/Stroke ratio: 1.67
- Pin Diameter: 18mm
- Comp Height : 1.030
- SOHC 16 valve i-VTEC
- Compression Ratio: 10.4 : 1
- Power: 88 kW (118 hp) / 6,600 rpm
- Torque: 145 N·m (107 lb·ft) / 4,800 rpm (GE8 Fit)
- Carbon Dioxide (g/km): 148
- Honda Fit (Japan series GE8 / 9)
- Honda Jazz (Brazil,Thailand GE8 / 9)
- Honda Freed (Japan series GB3 / 4)
- Honda City (India, Brazil, Pakistan, Thailand, Malaysia, ASEAN)
- Eligible for the F1600 Championship Series
