Farmer fuller
I currently have a major problem with my lower unit I currently only have forward gear I have messed around with the link rods. I can not find neutral all reverse what ever way I adjusted them I then decided to take Lower unit to bits and found that the dog clutch is not reaching reverse when the sprung loaded pin is pushed in it seems like the pin has warn out. Is this normal seems poor design as the pin just runs on two step wedge from gear linkage and wears it out.
am I missing a piece.
And can I use a different lower unit off a mucurey as I have read that they used them up to 1999 and what Lower units can I use off other Honda say bf8. Also what do people mean about a two piece drive shaft I only have ever worked on this one engine as it is my first one I have owned the lower unit has the crooked link rod if helps.
