beto_chamorro
Hi everyone.
First of all, please excuse my writing. I’m not very good at writing in English, so I use Google Translate.
Let me tell you the long story of my engine. I bought it six years ago. I tested it and everything seemed fine, but for the past four years, I’ve been having problems with it.
The first symptom I noticed was that, with the throttle at 100%, the engine would start to choke after a few minutes and eventually stall. I thought it might be the carburetors, so I took them to a shop to have them cleaned. The mechanic asked me to bring just the carburetor assembly, saying he could clean and tune them without the engine. He mentioned he had a lot of experience tuning Honda engines.
When I reinstalled them, the engine ran more smoothly, but the same issue persisted. After a couple of minutes at full throttle, it would start to choke. It would reach about 3,500 RPM.
I thought the fuel pumps might be failing. I bought genuine Honda pumps and replaced them, but the engine's behavior didn't change.
From the day one, I noticed a lot of "dead travel" in the throttle—movement that didn't actually do anything. I thought it was normal. When I installed the carburetors, I saw that the throttle cable wasn't adjusted correctly and wasn't opening fully. I replaced the cables and adjusted them properly.
When I took the boat out, if I set the throttle to 100%, the engine would drop back to 3,200 RPM once it passed that mark and stay there. At least this time, it didn't stall.
I wondered if the fuel lines were the problem—perhaps they were old and letting air in. I replaced the entire fuel line leading to the pumps, including the engine connector. I also changed the fuel filters and synchronized the carburetors.
I went out on the water this Sunday, and this time, the engine held steady at 3,200 RPM. At one point, I opened the throttle fully; the engine revved up to 4,000 rpm and the speed increased, but only for about 10 seconds. Then the rpm dropped back to 3,200 and stayed there. I dropped anchor, and when we set off again, I was able to get the engine up to 4,000 rpm for another 10 seconds or so before it dropped back down.
While we were underway at full throttle and 3,200 rpm, I tried pumping the manual fuel primer bulb. It would firm up after 3 or 4 squeezes, but there was no change in the engine's performance, and the bulb would go soft again after a few seconds.
I’m completely stumped and have no idea what the problem might be. What tests can I run to start ruling things out? What do you think it could be?
Many thanks to everyone.
