Hello, I have a 2011 Honda outboard BF50D on a 18' pontoon. To describe the concern: running at RPM's above 3,000 it will soon begin to surge as if it is running out of fuel. I have to back off throttle and allow it to idle when this happens. It does not stall when this happens, and it will recover and run as it should if I keep the RPM's below 3,000. I have a factory service manual but not much experience in the marine field. I recently replaced the separator filter and the high speed filter. pretty sure water is not an issue. When I replaced filters, I drained some fuel out of the vapor separator and it was clean. Have no idea how many hours are on this motor. There is a Honda gauge in dash that shows a mil symbol that comes on and goes off (seems as if it is working correctly). Have not tried to pull any codes yet. When the problem is happening, no mil light on. I have noticed the primer bulb is very hard to squeeze, if at all, even after overnight (not sure about that). It seems as if it is not getting the volume of fuel it needs to run. Any ideas?
Thanks, stedee
Thanks, stedee
