Hey, so a month ago i purchased a refurbished outboard from my local chainsaw shop who happens to also deal in and maintain various small outboard motors, ATVs, you name it. Its a small rural town so most buisnesses tend to be multitaskers.
This 5hp honda came with a guarantee that if it doesnt run as it should they would work on it until it does.
A month later they are baffled. You might say its their problem to fix it or reimburse me and they are not argueing anything to the contrary. But I do feel bad for them in such a small town and iam hoping to help point them in the right direction a bit if it might be something specific to these engines.
So to give a full picture.
The motor is used, from 2006 and stood idle in the back of their shop for years abandoned by its previous owner who didnt pay for his repairs.
Before selling it to me they did the following:
Ultrasonic cleaning of carb
testing cooling in a watertank
changing filters
new oil
testing if it runs on the first pull.
idled it and revved it.
they reportee it all worked perfectly in the tank.
Once i took it to my boat it started fine. however the throttle wouldnt go above start position wile in forward gear, after 30 minutes of running it just died and wouldnt start again.
Back in the shop they tested it and it started but blew Steam and hot water.
They changed out the thermostat, waterpump, pretty mutch every moving part in the system, adjusted some stuff i fail to remember on the throttle, new headgasket as well because it clearly overheated and they thought it could have damaged it (i am not mutch of a mechanic myself)
So i went out again today, started first pull, no problems until i tried to go full throttle, rpm would start dropping off as soon as i went past 3/4 throttle. Then after an unknown distance going that speed the engine just quit running again.
It would imediately start up again on first pull, but increasing throttle to a certain point imediately kills it.
starts up again, i try going home on the start position throttle, boat barely moved forward and motor dies again. Now i have to give more throttle to start again and lower imediately to keep it going a while.
This becomes a repeated cycle the whole way home, dies, starts and limps, dies again.
no sputtering, it just cuts the engine abruptly.
going over a shallow area i raise the engine up a bit and go at slowest speed to clear the area. Ofcourse at this point it cuts out no matter what speed i go. As i lower the motor again it sizzles and steam shoots out of the water hole for a second (motor is off at this point)
Basically it just keeps going like this for 2 hours until i limp it home.
Now iam no mechanic but i have been around engines before. Does this perhaps sound like its not getting fuel? Yes obviously i opened the vent on the tank.
fuel line is about 180cm long. the tank is under my seat directly in front of the motor.
So to summarise whats happening: cant go high throttle without rpm dropping at first, then just dies constantly but it does restart everytime.
changing filters
new oil
