Bought a 1996 Honda BF30A this spring and it was running poorly
could get it to run if you played with the choke but would die as soon as you put it in gear.
Took it to Honda dealer and the cleaned the carburetors twice put them back together but recommended I buy a new motor as they did not think it was worth putting more money into it. I Replaced the neutral switch as I knew it was bad, Then ran a bottle Mercury Quickleen thur it. Motor now runs and shifts fine but when you go to give it throttle it will die. Sometimes if you go slow enough or play with the choke you can get it to go.
Once past start up it runs good and will put the boat on plane with no problems.
I guessing they is different jets.
My question is it the carbs or could there be something else, would be is it worth trying to clean them again or just replace all three carbs?
Shop did say about 140 psi compression on all 3 cylinders.
