I'm not sure how that ^ makes it OK, but running a 21 on my engine stopped it going above 5200rpm - so it definitely WAS holding it back.I doubt it is holding it back, because it was delivered with the prop and the 19p was bought at 2012.
OK, what boat are you running? Length, beam, weight, hull type?
Wide open throttle (WOT) on these engines is 6000 rpm +/- 300. The ECU has a governor to keep it from over-revving.
Yes. somewhat. I took the boat to the shop, and he did some diagnostics and testing, everything responded normally and deleted faults i provoked to test if parts were working, so he did a ECU reset, had everything tested step by step, and could not find anything wrong with fuel pressure and ignition. So he sent me home, then i had a long interesting call with the guy that bought the engine, clearly telling me that this thing SHOULD have gained atleast 39knots with the 21" prop, but he got the 19" prop and gained 45knots. So i'm gonna put that on and test it. I need a new nut first, as they did put a merc nut on. and the threads was not right and it broke. Waiting for the new one now, ALSO he said the boat MUST be clean under, a few barnacles WILL take 5-10knots away since this hull run mostly through the water and not the 10% in water like a hydrolift or something. IF this works, then ive basically saved the engine and have been giving it a good service. the boat was OVERGROWN when i got it and there was even barnacle inside the prop exhaust house...... and almost out of sink. I will post the results when I get the nut and launch it. AGAIN :OAny progress?
OK, so dealer reckons that the engine is fine - spark plug threads OK also?
You never mentioned that the hull was covered in weed! Yes this will create a large amount of drag and, combined with the wrong prop, could be the reason for your issue.
I still think a 19" prop is wrong. My 21' boat is great now with a 17" prop and, as your boat is a bit longer, I think you should be trying a 15"
Glad to hear the engine seems to be OK - get that hull cleaned!
