Kingfisher2425
Hello, I have a 2006 Honda 225 HP serial number BAGJ – 1402456. The motor currently has 340 hours and has been well taken care of. I have clean fuel in the tank and have replaced the low pressure and high pressure fuel filters. I can drive the boat all day long at higher rpms with no issues. After we stop and fish for a while and then try to restart the motor, it will run fine for a few minutes and then it starves for fuel in the 2000 - 4000 RPM range and dies. It progressively gets worse, until the point it will not even fire when turning the motor over. I can always make it start and run fine by having somebody pump the bulb primer continuously. As long as I keep the RPMs above 4000 it will run perfect Once I stop and try to restart it or do low idle maneuvers the problem starts again. I know it's a fuel issue but can't determine if it's the low pressure or high pressure fuel pump, or something totally different?? Would the motor have flashed codes for the times the motor failed to run properly? I show no check engine light on the dash. The problem seems to exist after the motor has been ran under a load and after the engine has been used for 1/2 hour plus, I can never duplicate the problem in my yard with it idling.
Any advice would be more than appreciated!!!!
respectfully,
Wes in Alaska
respectfully,
Wes in Alaska
