basenjib123
Hello, I have a 2005 Honda BF20D that only has 8 hours time on it (long story). Anyhow, the motor has never idle smoothly whether hot or cold from day one. When I bought it and questioned this fact the guy said "well, they all run kinda rough until they break in". Anyhow it was stored for many years in a dehumidified garage and was started occasionally but it never idled right.
I have done the following to it ..Replaced: Fuel Chamber, Carburetor (not rebuilt but replaced with new one), new fuel enrichment valve, engine oil, filter, gas filter, fuel lines, water pump, new portable gas tank, primer bulb, hose and gas is fresh, waiting for new spark plugs.
Still after this nothing has changed it continues to run poorly at idle whether hot or cold. I have noticed some white smoke at start up sometimes. Checked plugs they are dry but black (I thought it was from the oil I put in the cylinders burning off). Pulled each plug wire and motor stumbles badly so I guess its firing ok. Also seems to be idling rather slowly when cold, shouldn't it be faster when cold? I did not mess with the carburetor idle screw since I assumed it is set at the factory.
Seems to me that whatever has caused this likely existed from day one and is still there but what that is, I don't know. Sure would appreciate any ideas at this point. Thanks in advance.
