JonnyBGood
Hi there guys
Recently I've used this forum for advice and now it's my turn to tell my story and ask some questions.
I recently got a new to me Honda BF20D. BAMJ-1507745. Not sure of the year. It was hard to start and after the previous owner ordered a new Stater enrichment valve and chinese regulator rectifier and connected the RR incorrectly, leading to smoke escaping the smoke container. He swiftly put it up for sale, finally done with it.
In I walk. Troubleshooting begins.
Enhine starts with FE circuit open but stalls as soon as it's closed.
Took the carb off and realised then were no gaskets either side of the isolator and the silencer gasket was in poor condition.Cleaned the carb. And ordered replacement gaskets. In the meantime made my own gaskets and put it back together. Now it actually started and idled but ran roughly, popping back through the exhaust and then dying after a minute or so and then would not restart. Idle screw did nothing from 2 1/8 turns out to almost out the hole.
Checked spark plugs they would fouled. Cleaned them up. And tried again same thing multiple times. Then read through this forum and then actually cleaned the carb properly this time. Got ahold of the Honda Marine Carburettor manual. Idle screw o ring found in poor condition. Blew through all the circuits and cleaned the jets in the ultrasonic cleaner. Interestingly I've only got a main jet size of 115... Can't find a 120 to buy in Norway at the moment.
Carburettor rebuilt with new o ring set. New gaskets installed. Idle screw still does nothing.
Adjusted float level.
Engine idles but engine RPM is hunting. Idle screw still does nothing. Squirted wd40 around the carb and then realised I had a vacuum leak around the isolator, found a crack in the isolator through a bolt hole. Isolator on order.
New isolator installed no vacuum leak there anymore potentially never was there...
Engine runs well. Starts with no issues, idles with no issues. But hesitates on acceleration and slow to deccelerate. Fast acceleration stalls the engine.
Using the tube on wd40 method I realised I might have a vaccum leak on the throttle shaft both sides. Took the shaft apart found a bit of play on the bush and reassembled with hylomar.
Runs maybe slightly better... But still hestitates and is slow to deccelerate. Hunting RPM has gone. Did not try fast acceleration.
I have read from jgmo that the accerator pumps do not work particularly well on these carbs. Or maybe I'm getting my wires crossed (read far to many of these posts) so I'm not too worried about the hestiation. But the slow deccel and the pick up in rpm when I spray the throttle shaft has me thinking am I focusing my efforts in the wrong place? Has anyone ever found a vaccum leak there? Are we worried about a vacuum leak there?
Kind of thinking it's about time for a new carb as I can't find part numbers to rebuild the trottle shaft assembly.
Any thoughts and advice will be appreciated.
And can I just say thank you to all those who contribute on here.
