Hi All, I am new to the forum but I have have read many of the older threads that mentioned BF20D's.
The engine has sat with gas in it from the previous owner for the last 3 years and has been difficult to start all along. So I wanted to get it running correctly so I embarked on cleaning the carburetor. I replaced all the O-rings and gaskets during the cleaning process. The only thing that seemed odd to me was the brass tube that is by the accelerator pump didn't seem to be drilled. I can only get a small wire to enter 1/8". I convinced myself that the tube is used on another model so I reassembled it all and still have a difficult time starting. For 5-10 minutes it will fire immediately and then die within a second or two. Once warmed up, it seems to run fine and starts first key turn. The carb is now on the bench again and I discovered I tore the Fuel Enrichment O-ring, I have a replacement now. Working to remove clog but not making traction, I left just the tube soaking overnight with the rest of the body dry. Still feels like it wasn't drilled.
Other things done: Using E0 gas, drained fuel chamber, replaced fuel filter, replace water separator, replaced plugs, all jets removed cleaned, inspected and reinserted, all other passages cleaned(I think)
I am hoping I am headed down the right path with unclogging the brass tube? Looking for ideas or suggestions so I don't ruin the tube/body.
Tim
Tim
