Hi, thanks for your reply..
I read in the Honda manual that the minimum clearance was the 5.9 inches as you stated..
I dont know heaps about boats so forgive me if I get some of my terms wrong..
I think part of it is too short too.. something about it being 25, when it should be 30? I just forget the description.
The place that fitted the engines is also the local Honda agent.. and the engines ran fine for a while, then the water jacket corroded on both of them (they are used in salt water and the boat is a water taxi).. once the short blocks were replaced they ran fine again for a while.. then the engine started running very rich.. and it kept killing the o2 sensors.. they kept claiming they couldnt find the fault but charged and charged and charged
.. the same place also serviced the engines every month..
For a while there both engines would stall when throttling down which resulted in a few close calls with some wharfs..
Eventually the problem was found to be the orings round the fuel injectors on both engines were leaking.
The place repairing the engines (same place thats done all the work and servicing) has been sending some very large bills.. the inlaws have finally put their foot down and I wanted to check on the idle port sucking in water as we think thats whats caused a lot of the problems..
