Recently purchased BF200 [2003] that ran great during sea trial only to get her home and find the water stream quit working and the alarm sounded at which time I shut her down and removed the lower unit. The impeller was trashed and the housing had over-heated at some point and partially melted near the O-ring. Purchased new housing, impeller, liner, gasket, O-ring and re-installed. Now the pee stream is strong but at idle the high temp alarm [continuous buzzer] goes off until I rev up the motor to about 1000 rpm's and the alarm will stop, only to return at idle and alarm once again. What steps should I take to correct his issue ? Thanks is advance for your advice.
Regards, Mudrod
Texas Gulf Fisherman
Regards, Mudrod
