I have acquired a project, a pre 1988 15 hp in need of a rebuild.
Hard to start etc, turns out it has low compression in both cylinders 90 & 95 psi.
So far I have pulled the cyl head and inspected the cyl bores, they appear to be pitted, may have been stored with moisture in the cylinders at some time.
Before I go any farther, providing the cyl bores will clean up within specs, can I hone and install new piston rings?
What is the cylinder composition nickasil or? And can it be honed successfully?
It doesn't appear that oversized pistons are available?
I don't believe this engine was ever been apart, what other service parts would likely need to be replaced?
Dave
Dave
