Anthomny Heaslip
Hi. I am new member - from Oztralya. The rubber bush on my propellor got chewed out the other day. I took prop off and have ordered new prop but there seems to be something funny going on in forward gear which may have caused the bush to chew out - or it may just be a coincidence.
Hopefully someone can help out there.
So, going into forward and reverse is fine. When I rotate prop shaft in reverse it doese the usual ratchet in reverse and sort of lock up in the opposite direction. I am assuming this doesn't fully lock as my Mercruiser 140HP 3.0L does because of it being a small engine.
Neutral is all fine too.
In forward it doesn't ratchet properly when I turn in clockwise direction it will turn but very difficult.In the oppositee direction the result is about the same.
I have taken off propeller bottom section and pulled shaft out and all looks good there. No oil issues. I haven't hit anything so don't believe it is a bent shaft. One thing I did notice was that the large nut to separate shift shaft is very difficult to move. Lock nut comes undone fine.
Let us know what you think.
Regards, Anthony H.
Regards, Anthony H.
