Hello All,
I am a new boat owner and have heard really good things about this forum.
Onto my problem, I have a 2006 bf150 and it will not start. I get NO click, click, click, ZERO!!!!
What I know: the battery is good, I had it bench tested, and I cleaned off the terminals. I checked the 90A large fuse and it looked okay, I did not have a tester with me but I would think if a fuse that large blew you would notice it. I checked all of the other smaller fuses in the fuse box and they seemed good as well. All of the electronics on the boat work, fish finder, gauges, lights, even the tilt motor worked fine. The safety switch clip was in place.
The light next to the battery with the (+ and -) symbols was showing solid red when I turned the key one position. I did work the gear/throttle back and forth in and out of neutral. Now I have to admit I am a new owner and when moving the boat around I did have some "interesting" moments when I had a little problem getting it in and out of forward and reverse to move the boat around and lets just say I was a little less then gentle with it. The motor ran no problem the last time I had it out but I didn't try and start it after I shut it off last time.
So, I guess my first question is could I have damaged the neutral switch (or whatever it is that tells the boat it is okay to start the motor) and if that is damaged would that cause the issue I described if you do feel like that could be it how would I go about checking it.
If you don't feel like that would be it is there something else to check.
Any advice would be greatly appreciated.
Kevin
Kevin
