When I go to get on plane the engine bogs down between 3800-4200 rpms. If I turn the motor off, cycle the key a few times to run the high pressure pump, then crank the motor it will plane off and run perfectly.
4 fuel filters have been changed.
Vst filter was cleaned
High pressure pump appears to be working properly
Low pressure pump is pushing fuel
[FONT="]16911-759-003 - I changed this fuel filter, but no fuel seems to be flowing through this filter at all.
Any ideas on what I should check? My best guess is the fuel rail isn’t staying pressurized unless the pump is running. Engine idles and runs perfect at lower rpms.
[/FONT]
[/FONT]
