www.boats.net
www.boats.net
www.boats.net
Thanks for reply, that’s what I was thinking of with seal, hopefully I can get a little deflection going up as powerhead casing is directly above, then pull start assembly, the latter being easy to remove, powerhead removal not so muchApologies....
I sent you links from the 9.9 hp parts pages.
Bur the concept is pretty much identical for the 15. See item 11 in the link below.
Honda Outboard 15HP OEM Parts Diagram for Vertical Shaft | Boats.net
Buy OEM Parts for Honda Outboard 15HP Vertical Shaft Diagramwww.boats.net
The part numbers are the same for both outboards.
Sorry though if I confused you.
