Hello,
I'm from the Netherlands and just bough a 15 hp Honda outboard. The engine has been sitting for about 3 years. I've been running the engine nog for about 3 trips, 7 hours. Yesterday the engine performed bad ad idle, when started cold the engine idles, but after one hour the engine became a bit jerky and won't idle anymore. Oil, sparks etc has been changed 3 years ago, and the engine did not run since now. What is the best thing to do, clean out the carb? Or is it a known problem.
Second thing, at WOT (full throttle) you can hear a slight rattle from the engine. When i lower the RPM just a little bit, it disappears and everything sounds fresh.
Third thing, at the end of the trip yesterday the rpms start to clime but not the speed. Is this due to a loose prop? And what can i do about it?
Fourth thing, when i yesterday get the cover off the engine, i was wondering if it needs an air filter housing. It doesn't have this: 17390-ZY1-000
Fifth thing, how can i adjust the carb. On the side of it is one screw which is turned 3,5 times from totally in. Is this the idle screw?
Thanks for the help ik advance.
