Hi
New here from the U.K.
I was trolling around for an hour and decided to move to another area. I increased rpm steadily upto 3800rpm after a couple of minutes the alarm started bleeping intermittently. All rpm's dropped to idle the red light came on the control box. The engine didnt miss or cut out. The motor idled smoothly. I turned the engine off to silence the alarm. I left it a few minutes and re-started the motor with no issues no red light and no alarms...I slowly increased power upto 3800rpm. After a few minutes it all happened again.
I stripped the fuel filters to check for water and all was clean. The fuel was fresh on that day.
I've since had a diagnostic done. Which returns an error with the Electronic Air Control valve. Or the 'Idle' IAC valve. I'm wondering if the IAC would cause the issue? Any suggestions appreciated
