Hi Guys
I have a bf130, not starting at all. When turning the ignition key ON, the high pressure pump is working, but no voltage on the injectors. Checked all wiring, + from the main relay is coming but - from the ESM is not. Checked for codes but no codes are present.
Went even through all the harness and checked all sensors. Was suspicious with the Map sensor so i changed it with a new one. Checked even all other sensors and seems that they are working fine. Checked resistance of injectors and they are around 14ohms (as per manual)
Any idea please
Any idea please
