Am DYI-bumbling thru a similar issue on my Glacier Bay starboard engine. BF130s, 1999 with the warrantied powerhead. No Mil light & No Battery light, no beep, on remote start, when trying to re-fire after over winter.
The engine has power, as the key will turn it over to start, just like always. However, no spark/kick, just like the safety-switch not pulled up or lanyard clipped on.
Have the maintenance manual; fault check sequence said to disconnect red-black wire to safety switch, then to check for spark, bypassing safety switch if bad. Did, so: still no Mil & Battery light cycles, and no change to cylinder ignition.
Thanks iang6766 for the simple 3-wire voltage check info, which the old BF130 maintenance manual won't say directly.
Port engine, re-fired just as normal, like it's been for 8 years. Is the first time this no Mil no Batt warning lamps at start cycle checks appear unresponsive, on the starboard side.
Both engines were fine, when boat was put up on blocks, last December. I've check every fuse I could find in the pilot station, and from the batteries, and all 6 fuses on that engine, just under the ECU-coils perferrated plastic cover, on Port side of powerhead. I was hopeful of finding a fuse or a smoking-gun corrosion event. Have checked as many of the remote station & on powerhead connectors that I can find. All looks normal and healthy.
Still need to do the voltage & continuity checks, but engine turns over, so it's got power. The ECU voltage supply leads locations & colors, and check points, is still an unknown for me.
Again, just bumbling along, with the big black potted mains relay out and in process of setting up for it's voltage continuity checks, as per the maintenance manual.
