NaymzJaymz
Hello again friends,
I'm ready to finally adjust the valves on my 82' BF100. In past posts it's been suggested to me that my motor idles poorly when hot due to poor valve adjust. I purchased a set of "valve" feeler gauges, but they only go down to .008 in. The Clymer manual says that the setting for my motor is .004-.002. in. This is the only motor, according to this manual, that has the same clearance for both the intake and exhaust. I bought a set of regular feeler gauges with the blades I need, but will this style do the job? Will I be able to get the feeler gauge down deep enough into the "impression" in the top of the head to measure the valve clearance without bending the blade of the feeler gauge? Also, can I take the valve cover off with the fuel pump and fuel hoses attached, or should I remove them? What do you all think of the valve clearance suggested by the manual? Does it sound right? Thanks as always!
