Can any one provide me any advice on my honda BF100 outboard.
When you first start the engine the oil pressure light is bright green but after a minuite or so the light fades out. As i dont want to run the engine with the light out i would like to find out whats wrong.
The problem started when i was running the engine when the light went out, i checked the oil and it was low so topped it up and every since then there has been a problem. I had never had a problem before this the light was always bright.
I have check the oil level and that is ok I have removed the oil pressure switch with the engine running and oil comes out , i have check the switch and this appears to be ok.
As the light comes on when i first start the engine could this be a problem with the pump or filter ??
thanks
steve
thanks
steve
