Hello, I tried to drop lower unit from my outboard and it appears the shift rod joint (at shift arm) in engine compartment must be removed from the shift rod. The diagram in book is showing threads. Of course I do not know how to get it off. It is getting hung up at the rubber grommet. It appears that you may have to disconnect the upper extension case and remove the lower unit from the upper case after it is entirely removed. Is this how it is done?
I was reading somewhere that you have to turn the case and leave the shift rod joint in place and count the turns. Unfortunately, I have disconnected the shift rod joint from the shift arm and I was spinning the shift rod. I don't know if I was turning just the shift rod joint on its threads or was it spinning from below. I turned it from the top and it stopped, but I did not count turns.
The question now is, do I try to reassemble it at the top with the pin in and then disconnect the upper case/lower case and spin and count turns? If so, how do I get it back to where it should be? I assume that I will have to get it in a position where it is in neutral and then see if I can shift it in forward and reverse.
I am trying to lower the unit to replace the gear shaft seal and the seal underneath the impeller. I have water getting into my lower case. When I laid my motor on its side, I noticed oil draining out the water intake tube at the bottom. Then when I stood it up more came out. When I run the motor in a tub excessive grease film appears in the tub.
Any help would be appreciated. If anyone has a mechanics book with step by step instructions for best removal , that would be appreciated.
