hi all, I’m having some trouble with my dads 2000 bf75
at full throttle after a few minutes an alarm goes off and it goes into limp mode. The alarm sound is constant and neither of the 2 lights on the control come on. If you put the shifter in neutral the alarm will go off and you can continue to full rpm for 30sec to a minute and it will do it again. If you just putt around or even half throttle it’s fine.
It has been reasonably maintained. It started this last year so I put a new thermostat in, no change. This spring I put a new water pump/impeller assembly in, no change.
I’m thinking maybe the temp or oil pressure sender but don’t want to just throw parts at it.
Any ideas???
Thanks,Al.
Any ideas???
Thanks,Al.
