gorantrener
hello, if some1 would help, important things first, all filters replaced (including HP), sparkplugs also, fuel line no issues, HP pump works fine at start. i have occasional problem somewhere in HP part or injectors... if i start the engine and run it up to 2000 rpm, never any issues. if i try to run it at 4000 FAST (which means from 2000-4000 rpm in few seconds) it occasionally starts to stall, reaches some 3000 but then engine doesnt answer (will not go up to 4000 or higher and starts to "shake" - clearly not receiving enough fuel). BUT, if i repeat same operation (from 2000-4000 rpm) very slow - 2500 for 20 sec, then 3000 for 20 sec then 3500 for 20 sec and finally reach 4000, and then seems to be working fine. as you imagine, very annoying. this mostly happens when boat is fully loaded (7m RIB with 10 divers). any ideas? should i clean the injectors (allthough i regularly clean with fuel aditives), or is it something inside that lower part of HP pump? is it possible the problem is with o2 sensors? thanks very much!!!!!
