I am replacing the head gasket on my pre 79’ BF100. I ordered a new honda oem head gasket off of a website and it is an exact match. I cleaned out alot of broken impeller pieces from the water jackets and passages. (Also replaced impeller). Reason for head gasket replacement was that the exhaust valves were bent I am guessing from a broken timing belt from the previous owner. I lapped in the new valves and am putting this old girl back together. My question is Should I put any kind of sealant on the head gasket? There doesn’t seem to be very detailed instructions in the honda oem repair manual I found online other than 18 ft-lb of torque on the head bolts and don’t forget the O-ring. The old head gasket seemed to have a thin clear rubbery compound on it so I wasn’t sure if I should use something other than just the gasket. I have never used any rtv or anything on a head gasket before but the substance on the old gasket makes me wonder. I also didn’t use any compound on the oil pump to head gasket as the old gasket didn’t seem to have any. Any help is appreciated.
